RichardT09
Message 1 of 3
Viewing recent incoming emails from a contact
I used to be able to do this by searching under a contact's name and up would pop a list of the received emails.This facility seems to be no longer available.Bright ideas please.
2 REPLIES 2
gg30340
Message 2 of 3
Re: Viewing recent incoming emails from a contact
Using the search box drop down arrow select "Senders" and enter the senders name/email address and select either your chosen Folder or select "All folders" from the drop down box along with the date you want to search from and it should find them.
RichardT09
Message 3 of 3
Thanks for the guidance.Worked perfectly and so simple once I knew how.
I had accidentally transferred an inbox email into one of over hundred files and didn't know which one.
Richard
