Message 11 of 15
Re: Why is my email showing in chinese and english?
@smegcat wrote:
Just opened in Chrome and it looks totally different. Problem is with internet explorer by the looks of it.
Time to ditch Internet Explorer.
Message 12 of 15
Hi, What happens if you do a F5 or a Control + F5? It looks like from the screenshot you sent, only the icons seem to be shown in chinese which feels like that part failed to load...
Message 13 of 15
It doesn't look like the language of your emails are affected. It appears that it is the "command" buttons that are displaying incorrectly. This could be a browser problem and you should do as Keith has suggested.
Message 14 of 15
Looks like it. Just bugs me that I can't work out why it is doing it. Most probably go in tomorrow and it will be fine.
Message 15 of 15
If you must continue using IE, then delete all of the temporary Internet files, there are probably thousands of cached files, which are not needed on a fast Internet connection.
IE is notorious for reserving vast amounts of disk space for its cache, which slows down hard disk based systems. It take longer for it to check the cache, than it would be to load the image from the Internet. It was fine in the days of dial-up Internet.
