calsgran
Message 1 of 4
Will not attach files using Safari
In the last few weeks I have lost the ability to attach files to an email whilst accessing via Safari but it works with Google Crome, any fixes please?
3 REPLIES 3
Moderator-Retired
Message 2 of 4
Re: Will not attach files using Safari
Hi calsgran,
Have you made sure Safari has all the latest updates installed? If you have no preference to use it over Chrome I would recommend just continuing to use Chrome if it works better for you.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Guru
Message 3 of 4
What OS are you using?  Safari is no longer being updated on Windows.
calsgran
Message 4 of 4
Thanks for the replies, having spoken to several people its not just with Safari. I will swith to Chrome I think.
