Do you mean
0
Yahoo Mail Beta: Annoying advert on right side bar, how to delete?
How do I get rid of the advertisement in the right side bar in my Yahoo Mail (Beta version). It means most of my messages have the ends of sentences cut off, and I have to scroll down to the bottom of the page to slide the bar so that I can read text. The trouble is, when I do that, I lose the left hand side, and I have to scroll back to the top afterwards! I am finding it increasingly annoying, as it makes reading emails a pain in the proverbial! Does anyone know how I can get rid of the advert bar please? Many thanks, Cal
Distinguished Guru
0
Re: Yahoo Mail Beta: Annoying advert on right side bar, how to delete?
Hi cal63 and welcome
Ah, so you've also noticed that the beta version prevents one from hiding the adverts on the rightSmiley Mad
Having said that, I don't get any!!Smiley Happy
I use Firefox with no script and ABP (plus several others) which removes the adsSmiley Happy, but currently not the space allocated for the adsSmiley Mad.
I can't help with the scrolling issue, as I don't get this.
-+-No longer a forum member-+-
Pi
Newbie
0
[ Edited ]
As you said, Adblock plus only hides the ads, but not the space allotted to them, and it's annoying! Luckily, there is a Firefox add-on which takes care of just that! Install Yahoo Mail Hide Ad Panel to automatically hide it everytime.
0
good advice however the post is 3 years old and BT Mail is shortly replacing yahoo mail
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
