Do you mean
Newbie
Accepted Solution
btyahoo
My wife has a lap top using windows8.  For no apparent reason when she tries to load bt yahoo the type face is so small it is unreadable.  can anyone help?
Re: btyahoo
[ Edited ]
Try pressing the Crtrl and the + key together. That should increase the size.
Crtrl and the - (minus) key together, makes it smaller.
Forumhelp (personal website) is back online with lots of useful info for BT customers. Some links may be out-of-date, but I will update them when I get time.
Guru
Re: btyahoo
And ctrl-0 sets to default size (which should be sensible, but ?)
Newbie
Re: btyahoo
Thaks very much
Newbie
Re: btyahoo
Thanks very much
