Peter19
Message 1 of 4
e-mail Block Sender section.
Can someone please tell me if there is a way to empty the Block Sender list  in the E-Mail section.  It seems that I have blocked 60 Senders previously and have reached the limit.
Thank you.
Peter.
Peter.
Swansea.
3 REPLIES 3
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: e-mail Block Sender section.
Can't you simply click the senders you want to remove and click "Delete"?
Carlusha
Recognised Expert
Message 3 of 4
Only 60? My account allows 5000!
While in email, click on your id (top right), select settings, select mail, select blocked senders, flag the little box at the left of each you wish to remove. That done, press the delete button (on the right).
Peter19
Message 4 of 4
Thank you very much.
Peter.
Swansea.
