Windows 10 on two Medion Desktops.
When I go to the BT Mail log in page I have two accounts on which the system auto inserts the saved password, I 'show' password and it is correct. When I press the enter key, a number of extra dots appear after my password. I then log into emails, this also happens on another desktop. If I run CC Cleaner this does not happen for a few log ins then it starts again. I did contact BT helpdesk about this and they said it was a system problem they are aware of and that it would be cured in 24 hours, this has been going on for nearly a week.
I have changed my password as a precaution but it is still happening, I am concerned that this is some kind of tracker?
Thanks Foe looking
Ray
Solved! Go to Solution.
