iansally
Message 11 of 32
Re: email printing problems
I clicked on the icon (torn page) and the message "Internet Explorer has Stopped Working". I tried again ( NO IE has stopped screen) and the screen seemed to refresh but alas still only Headers and Footers in Print Preview mode as well as actaul print.
Message 12 of 32
Sorry that's me out of ideas at the moment. I'll do some searching and see if I can come up with a solution and post back if I find one.
Message 13 of 32
I have just tried it in Firefox browser and it works OK so this would suggest as Ray has said, it is a problem with IE9. You could, until a fix is found, download Firefox and use that to access your BTYahoo account.
Firefox is a very good browser and you should have no problems using it.
See link for Firefox download
http://www.mozilla.org/en-US/firefox/new/
dvdcks4
Message 14 of 32
I have had the same problem with IE -- I get an error message re script -- must try firefox
iansally
Message 15 of 32
Thanks for that gg30340. But before I try it I must tell you something; Nearly every time I try to attempt to print something from BTYahoo Mail the "Internet Explorer Has Stopped Working" message is displayed. When I try printing from any other web page there is NO "IEHSW" message and the document prints perfectly.
Do you still think i should proceed or wait until you have thought about my reply.
Message 16 of 32
Try Firefox meantime, I'll post back if I find out what's happening or hopefully somebody else has had this problem and already knows the fix.
Message 17 of 32
I am not sure why it would only be happening with the BTYahoo site unless it is a script problem with the site. I don't think this will sort it but is worth a try and that is to reset Internet Explorer, you can do this by:
·         Close any Internet Explorer windows
·         Click Start
·         Click Control Panel
·         Open Internet Options (you may have to switch from category view to icons to find this)
·         Click the Advanced tab
·         Click Reset…
·         Click Reset
·         Click Close
·         Click OK
·         Open Internet Explorer
 Try printing email now.
iansally
Message 18 of 32
It has worked. I assume this is a temporary fix until something happens in cyber space to get me back to my old program.
Thank you once again gg30340 and Ray.
Message 19 of 32
What part worked, the downloading of Firefox or the reset of IE9
iansally
Message 20 of 32
The downloading of Firefox.
I will try the reset of IE9 but how do you restart IE once completed
