Message 1 of 5
iphone Login Issues
As of today my wife cannot connect to bt email on her iphone, but I can, and our settings are identical. Tried deleting the account on the phone, but still get 'mail server is not responding'. Tried messaging BT but the button doesn't work ? Any ideas, thanks
4 REPLIES 4
Message 2 of 5
Re: iphone Login Issues
It is/was probably a BT server problem. The best advice when it happens is to do nothing, especially do not change passwords or delete the account from your phone as that can cause more problems than it solves.
The first thing to do when it happens is check to see if you can log on to your email account via a web browser. If you can there is obviously nothing wrong with your password or account hence the advice to do nothing.
If the problem did not resolve its self after a day or two or in your instance where you have deleted the email account from her device you should stop the iPhone and any other devices from checking for email. The easiest way of doing that is to turn them off if you still have the account on your device or add a couple of characters to the email address so that it is not checking your account. If you have deleted the account and it is no longer on your device do not try and add it at this time.
Once you have done that, change the email password and check that you can access the email via webmail (on a browser).
If that works you should wait at least an hour to allow the servers to sync and then add the new password to the iPhone, remembering to remove any characters you may have added and again check it works. If it does then move onto the next device if you have one.
When entering the settings, make sure that in the Outgoing server you do not use the "use same as incoming" for the email address and password. Enter them manually.
If the above does not resolve the problem, when you change your BT password on an iPhone/iPad/Apple device it may only change for INCOMING mail.
To change the outgoing mail password you have to go into Settings; then scroll down to Passwords & Accounts or on older devices Mail, Contacts, Calendars. From there select the BT email account and select the account where it is listed under IMAP.
You will find the details for the account and can change the password for the Incoming server there, the outgoing mail server only shows SMTP and mail.btinternet.com You have to tap on that Primary Server in order to find where the Outgoing password is hidden so you can update it.
When setting up the email account on your device you are best to set it up manually, using "other" and ensure that you are using the correct settings as per this link.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Message 3 of 5
Thanks ... we will see what happens tomorrow.
However trying to log in via a PC she gets
'your account is temporarily locked. Please retry in 20mins"
Still says that after 20 mins 😞
Lets see what tomorrow brings, and I will try what you say.
Message 4 of 5
does not work and within hours
Message 5 of 5
Hi @TimEwins
I'm sorry that you are having trouble reaching the chat team. I've just tried the chat link myself and I'm getting the same, so I'll get it reported.
In the meantime, if you are seeing the same thing on your wife's email today, and the steps that @gg30340 mentioned above haven't helped, I'd recommend giving our email team a call so they can look into this further for you.
Michael
