Message 11 of 15
Re: outlook problems
Hi Barnpiece,
Thanks for you reply. I may consider forwarding the emails to my gmail account if the problem persists.
Never done it before. is the process quite straightforward? Is there a copy of the email left in the outlook account when forwarded
Message 12 of 15
thanks will watch with interest
Message 13 of 15
Thanks for your reply. I also tried the advance set up and it wouldn't work . Might give the different port number a go though
Message 14 of 15
@IDO wrote:
Hi Barnpiece,
You do not forward emails from Outlook. They are forwarded from your BT email account. Assuming you are on the BTMail system  you have to log onto your email account via webmail and go into the settings and select "mail" > "Auto Forward" then enter the relevant details of the account you want the emails forwarded to.
If you are on the BTYahoo system it may be slightly different but the end result is the same.
Message 15 of 15
Thanks for advice, will give it a go if problem persists
