Message 1 of 3
updated email system
Now that BT have changed the email setup, I am no longer able to hold the mouse over incoming emails, to see whether it is a sender I recognise or not. Consequently I am no longer able to decide whether to block spam senders or spam domains. Is there any way of restoring this very useful facility please?
2 REPLIES 2
Message 2 of 3
Re: updated email system
If you hover the mouse just below the senders name it will show you what email address it originated from in the same way as the "old" email interface did. When you hover your mouse the pointer will change to a "hand pointing" when you hover over the viewable spot. This will not work if the name is an email address rather than a name.
If you want to view the full source of the email select the email with a signal click the box to the left of the email in the list. This will not open the email and you then go to "More" in the menu bar and then "View Source".
Message 3 of 3
Many thanks. Simple solution but it was escaping me!
