Message 11 of 174
Re: issues logging into BT webpage
same thing is happening to me. BT web mail page won't load. Was working last night.
Message 12 of 174
Re: Are BT emails down
Down here in Wakefield
Message 13 of 174
Email/dns issues when connected with wifi
Hi, having issues refreshing BT email app when connected using wifi. Cant even access email.bt.com
Works fine with data connection
Message 14 of 174
Same thing in Dundee
Message 15 of 174
Is that a setting on the BT hub page or on local device? thanks
Message 16 of 174
... and in Wales...
Message 17 of 174
BT are aware that email is down, back office are trying to fix it but it might take 24 hours.
Paraphrased from a chat with the 24  hour support team.
I can give no further information - I'm just a customer.
Message 18 of 174
Hi Paul R
Could you please explain how to change the DNS setting for BT mail - is that in the BT hub settings or on the local device settings. Thank you
Message 19 of 174
@Vic156 wrote:
Hi Paul R
Do not change anything. There is a problem at BT's end. If you change your settings you will only cause your self more problems.
Message 20 of 174
....and in Portugal..
