Message 21 of 174
Re: Email/dns issues when connected with wifi
@DazzyJef BT Mail is down, it might take 24 hrs to fix. Chat support asked me to use the app but I get a "No network available" message.
I don't know what you mean by "Works fine with data connection".
Message 22 of 174
Re: Are BT emails down
Same in Dorset. 😩 So frustrating, I can see email notifications but won’t refresh. Using iPad and my phone.
Message 23 of 174
Re: issues logging into BT webpage
@englandjeff
Are you able to log into your email via BT Email Login
Ali
Message 24 of 174
If you have a mobile phone, switch off your wireless connection and use your mobile phone's 4/5g connection as this appears to be working.
Message 25 of 174
@Distinguished Sage
Brilliant - thank you for suggesting this workaround - worked for me.
Message 26 of 174
same issue - it appears to be dns problems at BT. If you take off WiFi and use 4G access to sites restored..
come on BT  get this sorted.
Message 27 of 174
Message 28 of 174
Same in Newcastle
Message 29 of 174
We are out in Essex
Message 30 of 174
Thanks very much Distinguished Sage - that's worked for me... brilliant 😀
