Message 91 of 179
Re: Are BT emails down
Nothing working for me here in East Sussex either. This has been a few hours now. A bit disappointed at lack of response or fix. I just get ‘server not found’ when I try to access directly. Not working on any devices.
Message 92 of 179
The app isn't working either
Message 93 of 179
Same here, and flushing the DNS has No effect.
Message 94 of 179
I found that it is not only email that is affected. Some websites are also not loading. BT should be communicating better to customers.
Thanks to advice here, I ran my VPN and all problems are gone which suggests a DNS or network routing issue with BT.
Message 95 of 179
There is access via VPN and 5G.
Message 96 of 179
On Berks/Surrey/Hampshire borders. I can access mail on iPhone and laptop with WiFi, but wired access through the router from my desktop doesn't work.
Message 97 of 179
I can't access emails via wifi or on the app; I can only access via VPN
Message 98 of 179
All of the sites I have seen not working, including mine, are using DNS services provided by godaddy.  That is BT nameservers not resolving domains that are hosted by godaddy
Message 99 of 179
Thanks for the VPN suggestion.  Just turned on Norton's VPN, reaccessed Outlook and all emails came through.  Weird.
Message 100 of 179
Tech chat is useless tbh - just hope this is fixed soon 😩
