Message 1 of 8
Audio memo won't play
I have received an email containing an audio memo from a btinternet.com user who is not know to me. I thought I'd try to download it and scan it but there doesn't seem to be a down load option. If I select "Preview" I get presented by a screen titled
"BROADBAND EE" and has a link captioned "click here to listen"
and if I click it I just get presented with another email login screen
Anyone seen one of these before ? is it dangerous  ?
7 REPLIES 7
Message 2 of 8
Re: Audio memo won't play
if sender is not known to you then I would not be opening any attachment which they have sent more delete it
Message 3 of 8
You're probably right. I just thought this might be a message delivery that BT/EE might employ but I'd not yet come across it.
Message 4 of 8
You should never click on any links or download anything unless you 100% know who it is from and what it is that you are dowloading or clicking on.
Even then unless I asked for the item to be sent that was to be downloaded or knew where clicking the link would take me I would check before doing it.
Message 5 of 8
Yep, thanks
Anonymous
Not applicable
Message 6 of 8
there person email thats is known to you are they known to your personally there email address may have spoofed or hacked if it were me i wouldint be opening any email that look that suspicious anything that send you to a login page for a voice recoeding is odd may be used ny a hacked email account to get your details
much less downloading a file  block this email until you can verify this but id say this is spam
might be wise to do a full system scan aswell
Message 7 of 8
HI @Willmouger
If clicking a link from an unexpected email takes you to a log in page, it may be a cloned log in screen in an attempt to capture your details.
To be safe please have a look through What is a phishing scam? Is the email I have received genuine? and follow the steps under 2. I think I've received a phishing email. What do I do?
Ali
Message 8 of 8
Yes, did a scan and all clear.
