Message 1 of 2
Blocked email - how do I unblock?
I think I inadvertently blocked an important email.   How do I unblock it so I can continue to receive from the address?
1 REPLY 1
Message 2 of 2
Re: Blocked email - how do I unblock?
Log onto your BTMail account using a browser, not an email client/app, and then click on your username at the right hand side. Select "Settings" then go to the left hand side and select "Mail".
Scroll down and click on "Blocked Senders". Scroll down the list until you find the email address or domain you want to unblock and select it.
Click on the small "Trash" symbol at the right hand side.
It will only delete the email address from the blocked senders list not your contacts list.
