Message 1 of 8
DNS not recognised
Hi I cannot open my emails as I get a message saying DNS not working.  I did get an email from what was called "administrator" saying I was using and old domain but as it was not sent to me personally I thought it was a scam so didn't open it.  How can I fix this in retrospect.  Big thanks
7 REPLIES 7
Message 2 of 8
Re: DNS not recognised
Try restarting your BT Hub. If that does not work try a factory reset of the BT hub by pressing a pin into the recess button on the rear for about 20 seconds.
Message 3 of 8
Thank you for your reply.  I have a talktalk router not a BT hub
Message 4 of 8
if using TT router are you a TT customer not BT Retail?  If TT then you need to post on TT forum
Message 5 of 8
Message 6 of 8
TalkTalk DNS for bt.com has been down for 3 days now. TalkTalk users can't access any BT services, causing so many calls and complaints being raised with BT.
There's a 3 day old thread on the TalkTalk forums with no reply from them so far.
Message 7 of 8
Thank you that is a real help to know.  I seem to be able to access my email on my phone now but not on my lap top - crazy!
Message 8 of 8
Email back up and working - thank you all
