Message 11 of 14
Re: Distinguishing unread emails
Hi,  Did you find a solution? if so could you let me know as I have exactly the same problem it has been fine for years and years but this week the problem has appeared so I cannot distinguish read and unread emails.
Phil
Message 12 of 14
Good morning @Philip58.
Welcome to the BT Community 😊
Just to be sure, is it BT Webmail that you're experiencing this issue with?
If it is, can you give this a try from a different browser to see if you're experiencing the same on there?
Peter
Message 13 of 14
Hi Peter,
Thanks for replying.
Yes it is BT Webmail.
I am using a MacBook so I think I have to use Safari.
I will try it from a Windows PC later and get back to you.
Phil
Message 14 of 14
Thanks @Philip58!
Please keep us posted on how you get on, and if needs be we can get this flagged with our email team.
Peter
