Message 1 of 8
Email Block sender
I am trying to unblock a sender from the block list, but I can't find how to do it. Where is the blocked list?
7 REPLIES 7
Message 2 of 8
Re: Email Block sender
Log onto your BTMail account using a browser, not an email client/app, and then click on your username at the right hand side.
Select "Settings" then go to the left hand side and select "Mail".
Scroll down and click on "Blocked Senders". Scroll down the list until you find the one you want to unblock and select it.
Click on the small "Trash" symbol at the right hand side. It will only delete the email address from the blocked senders list not your contacts list.
Message 3 of 8
I have done that but the site still does not work. Also there is another site which cannot email me with receipt's .
Message 4 of 8
Were the email addresses in your Blocked Senders list?
Have you added the email addresses to your Safe Senders list?
Message 5 of 8
I have tried to add the address to the safe senders list but and error message comes up with email already in blocked sender list , but I cannot find it on the list.
Message 6 of 8
Check for the domain, the part after @ in the blocked senders list.
Message 7 of 8
Have found out how to search (command+f) brings up a search box enter address and found the one I as looking for. removed it and added it to safe sender. Hopefully that will work. I will let you know if it works.
Message 8 of 8
Seems to be working ok now. Thanks for your help.
