Message 1 of 9
Emails, desktops and android smartphone
I have a Win11 desktop, with Thunderbird installed.
One of the accounts is  ***@btinternet.com.
The  server is POP (mail.btinternet.com.);  the port is 995
Security is SSL/TLS
Authentication is Normal password.
I have a Samsung A25  - the current email address on this is *****@gmail.com.
When I first acquired the A25, I installed my default email address. The problem was that all the existing emails to/from the default address on my desktop were sent to my smartphone - which I did not want.
I removed that account from the smartphone. and opted for Googlemail.
  I have experienced considerable inconsistency in using Googlemail.
As a result, I intend loading Thunderbird on the smartphone, with the intention of using my btinternet.com  email address on the smartphone.  As I don't often use the btinternet address on my desktop, I have few emails in that inbox, which I can empty.
However I prefer to keep the account on the PC as a standby.
What obstacles will encounter when I try to  copy my Thunderbird/btinternet account settings to the smartphone?
8 REPLIES 8
Message 2 of 9
Re: Emails, desktops and android smartphone
None whatsoever, however, I would recommend Blue Mail rather than Thunderbird on your phone.
It won't sync with your desktop though (which I guess is what you want) as that is POP3 rather than IMAP.
Message 3 of 9
Thanks.I have installed the BTmail app, and it is all working.
I guess I can change the sync settings if I need to. I assume the Thunderbird account will still pick up the btmail anyway.
Regards
Message 4 of 9
The BT mail app wouldn't be my choice!!
If you mean the Thunderbird account on your PC, yes it will still receive as normal but anything you send from the phone  won't appear in the sent folder on the PC.
Message 5 of 9
I agree with @licquorice . BlueMail is far better than the BTMail app.
Message 6 of 9
I will investigate at least the BT app got me off the ground as it were :))
Message 7 of 9
I've had a look - in a nutshell what are the advantages?
Message 8 of 9
Try it and you will see.
For one thing you can use it for multiple email addresses from multiple providers.
Message 9 of 9
In Thunderbird, I have two accounts - each from a different server.
So far Btmail seems to work ok for me🙂
