Message 1 of 3
How do I get more old emails to be loaded onto my inbox? currently it only display current few weeks
Hi,
Can anyone advise how to set up BT email to load more than 2 weeks of emails in Inbox please? It is difficult when you try to reply to older emails and it is not listed in the inbox.
Thanks.
Kevin
2 REPLIES 2
Message 2 of 3
Re: How do I get more old emails to be loaded onto my inbox? currently it only display current few w
Make sure that the "Conversation" View is not active. To do that log onto your BTMail account and click on "View" in the menu bar at the right hand side. Scroll down and Single click "conversation view" to toggle it on or off.
When you toggle it on or off you will see the name "Conversation View" change colour from grey to blue when it is turned on.
Message 3 of 3
Excellent, it works.
Thanks for your quick advice.
Much appreciated.
Kevin
