Message 1 of 2
How to read older messages. Again!
Hi. the other week I looked into this. Well it was about eight to ten weeks ago really. I wanted to check my older messages. Someone suggested using 'Conversation View'. That was great and it worked a treat. But now, for some strange reason, even using that DOESN'T work anymore! Don't BT want me to be able to check my older messages? Today is Sunday  10th May, at 16:20 and the furthest I can go back into my previous emails is Saturday morning (9th. May). Please someone tell me why? And if there is some way of checking these older messages? As I can't always read them on the day they're sent, and also, I regularly have to check way back for things and deal with something sent weeks ago! Well this is no good on BT at the moment and I will have to change my email provider if this cannot be fixed! Is it something security related, as I expect? Or is this latest problem fixable?
Many thanks, Gilbo.
1 REPLY 1
Message 2 of 2
Re: How to read older messages. Again!
Hi @Susan27,
Thanks for visiting the BT Community
Do you use both the BT Webmail and the BT Mail app? Is the issue effecting both or just one of them?
Conversation view will group related message together but turning it off should default to showing each individual email, so may be best if you are trying to find specific emails. Usually emails will be loaded 50 at a time, so by default it would show your 50 last emails but scrolling down should load 50 more and so on. Is this not happening when you try?
If you are looking for a specific email if you use the search function is the email found that way?
Alex
