Message 1 of 5
Login required twice
When i want to look at email I login using ID and password. I then get a home page, email is a title top right. click on it and I get the sign in procedure again. ID and Password. This is stupid and frustrating. How can I get direct to my email when I first sign in. thanks.
4 REPLIES 4
Message 2 of 5
Re: Login required twice
By using the direct login
https://email.bt.com/mail/saf/login.jsp
Message 3 of 5
It now a "new" feature of BTMail.
You can work around it as follows:-
Log onto your BTMail email account. Once logged on go to the address bar and it should show the page address and version of the email you are on.
Now click on the Inbox icon at the left hand side and then click on the address bar favourites icon which should open a new drop down box showing the page that you are going to make a favourite.  It should now show "Inbox and your email address"
Add this as favourite then log out of your account.
Now when you want to log on use the new "Inbox"  favourite you have just created. It will bring up the log on page and you then log on as normal and it should take you directly to your Inbox list of emails.
Although you are using the logon page for the email account you copied the favourite from you can use the logon page for any BTMail email account and it will take you to that account not the one you used for the favourite.
Message 4 of 5
Got it sorted many thanks. Holmass
Message 5 of 5
Ta for the help. Holmass
