I know this has been a common problem and the forum's posted solution below in italics used to work for me when using Google Chrome. But it no longer works and I am now forced to use Microsoft Edge to access my email. Any alternative solution(s) anyone can suggest so I can revert to Google Chrome? Thanks in advance.
"Press F12, there's a top menu in the developer window (elements/console/sources/network/ etc). You may need to scroll right on the menu bar (or expand the size of the developer window to see all options).
Select "Application". You should then see a menu down the left side of the pain which includes "Storage"
Click on "Storage". There is then an option in the developer pane to "clear site data" along with a check box to "include 3rd party cookies"."
Just clear your browsers history and cookies.
Make sure you select "From All Time".
It's true that a solution is to clear cookies for BT domains, but let's face it, this is only a workaround for a problem in BT's system. It's only started happening recently. It's not like we're doing anything different, so it must have been caused by a change in BT's software.
What I don't know is whether BT are aware of the issue, and whether anyone is doing anything about it.
@docdunningwrote:It's true that a solution is to clear cookies for BT domains, but let's face it, this is only a workaround for a problem in BT's system. It's only started happening recently. It's not like we're doing anything different, so it must have been caused by a change in BT's software.
.... or a problem with Chrome for some Chrome users because it does not affect every BTMail user using Chrome or BTMail using any other browser.
If it is resolved by clearing the cookies it could be that Chrome is retaining "older" cookies instead of refreshing them if new ones are released.
.... or a problem with Chrome for some Chrome users ...
Point taken.
But there's clearly an incompatibility issue - it's not user error.
I just logged in successfully to webmail. Then I clicked the "Log out" link, and got BT's purple dots just endlessly turning. The browser console shows:
/mail/bin/auth:1 Failed to load resource: the server responded with a status of 400 (Bad request)
/mail/index-rui.jsp?…MX_3.12.0.1#/mail:1 Uncaught (in promise) Object
And unsurprisingly, when I try to log in again, I just get the userid/password boxes looping in and out of view. Yet again, sigh, clear the cookies and it works again.
If it was my website that was failing like this, I'd at least be looking into it.
