BT email using Firefox browser on a desktop. In one only of my folders, all emails prior to March 2025 have disappeared. How can I get them back?
Thanks in advance
Do you use any other devices to use your BTMail account?
Presumably you have checked the Trash folder?
Generally if your emails are not showing on webmail it means that they are not on the BTMail servers.
If you call BT 0330.1234.150 and ask for the BTMail email team they may be able to help however when this has previously happened they can usually only tell you what device triggered the deletion.
As stated you will need to contact the BT email team. I suspect that they will inform you that one of your Apple devices triggered the deletion. They may be able to recover the emails but I would not hold out a lot of hope.
