Message 11 of 15
Re: No longer possible to edit event times in calendar.
Please forgive my impatience but I first raised the issue last October!
Message 12 of 15
I have recently noticed that it is possible to select the length of appointments in 15 minute intervals. OK, that's a small improvement, but where's the logic then times can only be set at half hour intervals? And even being able to log appointments as quarter hour intervals is not good enough. My eye test this week is at 11.25 or, as I had to enter it, 11.30 with a note "Actual time: 11.25". Ridiculous!
Message 13 of 15
Set it at 11.15 and arrive early.😄
Message 14 of 15
I'm looking for action. And you can't set 11.15, only 11.00 and 11.30. It is only the event length that can be set in 15 minute intervals. The system is not fit for purpose.
[Mod edit: response edited to align with community guidelines]
Message 15 of 15
Hi @SteveB21
Thanks for your patience with this. I've reached out for an update, and will get back in touch once I have further information next week.
Ali
