Message 1 of 2
OK, I admit defeat. How do I add 5 BT email addresses into my BT ID email account as a drop down?
Okay, I have my main BT Email account and a further 5 email addresses that I need to add to my main BT Email account in the form of a drop down from my main account.
At the moment I have to open BT using User and PW, then select Email and re enter User and PW again to login. then to open another email I need to log out of my main account and re enter using one of the other 5 emails  User and PW. It's driving me mad! I have read that it is possible to ADD other BT emails to my main BT email account as drop downs.
Open BT  and my main account ID and access my other emails from that already open account.
Any help would be appreciated as it's doing my head in.
The questions only easy if you already know the answer
1 REPLY 1
Message 2 of 2
Re: OK, I admit defeat. How do I add 5 BT email addresses into my BT ID email account as a drop dow
The drop down is no longer available in BTMail.
You could add them to your email account by going to the settings then add an account.
This will have all the accounts listed on the left hand side below your folders and you can use them from there.
This in effect turns your BTMail in to an email client.
You could also use an email client/app and add all the accounts to that.
