Message 11 of 14
Re: Outlook connection to BT Mail
You haven't answered the question posed in message 8 of the thread.
Message 12 of 14
Oops - apologies.
I am a BT Broadband customer. The email account type is "Standard" (sort of a "grand-fathered" premium account I guess)
Cheers
Paul
Message 13 of 14
You can try forcing a change of IP address which might then result in you connecting to a different server in the farm. Disconnect your hub from line for about half an hour to trigger the change of IP address.
Message 14 of 14
Hi all - found the problem.
I have (had!!) Norton 360 running.  Turning it off seemed to do nothing, so I completely uninstalled it - suddenly my email flashed into life!
As such, issue was on my side, I can only think that Norton really did not like the port being used, or perhaps the connection through to IMAP? Anyway - it is now resolved, and thank you all for the help!
Cheers
Paul
