Message 1 of 3
Re: BT EMAIL ACCOUNT
Has BT lost the plot, when this happens you get locked out of your account but BT send a PIN to that email account to verify it's you.  How are you supposed to access the PIN?
2 REPLIES 2
Message 2 of 3
I moved your post so you can get replies to your problem as the thread you posted on was marked as solved
Message 3 of 3
Did you set up an alternative email address in your MyBT to be used in instances like this?
