Message 1 of 5
Spam Blocking
I get a ridiculous amount of emails in my Spam folder, which I know I can just delete, but I'd like to know if there's a way of blocking multiple versions of the same domain. For example, I get emails from @ABC.spam.com and @bcd.spam.com and @CDE.spam.com etc etc, and I would like to know if there is a wildcard I can use to block @everything.spam.com because just blocking spam.com doesn't work.
Hopefully that makes sense!
4 REPLIES 4
Message 2 of 5
Re: Spam Blocking
Morning @Zummerzet
Thanks for coming to the community.
Our Using BT Mail's anti-spam features page has information and advice on how to block spam emails.
Thanks.
Leanne.
Message 3 of 5
Re: Spam Blocking
I have same problem with multiple versions of same basic domain.  e.g    @aosvh.pinterest.uk.net and  @ZMortyuios.pinterest.uk.net
The question is - is there a wildcard that can be used to block these domains e.g *.pinterest.uk.net or %.pinterest.uk.net.
The BT help page on the link given in previous answer does not contain this information so a simple  No or Yes with details of available wildcards would be appreciated.
Thanks.
Message 4 of 5
Re: Spam Blocking
No wildcard but you can block a domain although it is a waste of time as spammers just change the domain frequently.
Message 5 of 5
Re: Spam Blocking
Thanks for understanding the issue! From the one word reply you've received, I'm assuming there is no way of using a wildcard, which is pretty poor, in my view. But it is what it is...
