Message 1 of 6
Specific Email Address Notification
My car tracking company doesn't send me a text message when my car is being moved out of hours overnight, they only send an email which I wouldn't get to read until the next morning. Is there a way to get a notification sound on my phone when a particular email comes through (ie the email from my car tracking company to say my car is moving out of hours)?
Any help and guidance will be most appreciated  and then I can let others know.
5 REPLIES 5
Message 2 of 6
Re: Specific Email Address Notification
You can't get notifications for specific emails, you either get all notifications or none.
Message 3 of 6
A workaround would be to create an email address specifically for that purpose and use it with a different app so it would be the only email address causing notifications for that app.
Message 4 of 6
Great answer but complicated for me when I feel, frustratingly, that the tracking company should be able to contact me directly.
Message 5 of 6
Very frustrating Licquorice. The last thing I need is constant pinging throughout the night. Thank you for passing on your knowledge.
Message 6 of 6
Hence the workaround.
