Message 1 of 4
Sub Folders missing
Hi I hope someone out there can help. I’ve recently been checking my folders and sub folders within my inbox and have discovered several have gone missing, I’m wondering if anyone else has experienced this and how they managed to retrieve them?
3 REPLIES 3
Message 2 of 4
Re: Sub Folders missing
Hi @g_bullard.
Welcome to the BT Community!
Just to check first of all, how is it you're normally viewing your emails?
Is this via a dedicated app / client, or are you logging in directly to BT Webmail?
Peter
Message 3 of 4
Hi I tried using Outlook, Thunderbird and finally logged direct into the web server all efforts showed the same results. The same sub folders missing from my folder tree.
Message 4 of 4
Thanks @g_bullard.
I've just sent you over a private message so we can take a closer look into this 😊
Peter
