Message 1 of 3
Template Email
Can I set up a template email that will allow me to send to individual recipients each with a different set of attachments?
2 REPLIES 2
Message 2 of 3
Re: Template Email
Hi @Samrob2
This doesn't seem to be a feature that's available through webmail or the BT Email app. However, there may be a third party email client that you could use to do this. I've seen others in the community recommend the Thunderbird app. Although we have no support for that app, it may be worth giving it a try if this is a feature you really need.
Chris
Message 3 of 3
Re: Template Email
Thunderbird Setting up template
See link
https://kb.mozillazine.org/Message_templates
