Message 1 of 20
Unable to get login screen
When I try to login to my BT mail via the web page www.bt.com i get the following error message returned, this is before I even get the screen to enter my login details:
The request is blocked.
20260209T170431Z-174b4b6ddbffqt68hC1LONcm8w0000000n6000000000afqg
This is on both a PC and Apple mac. I can still download messages on my iPhone.
Anyone else got this problem?
19 REPLIES 19
Message 2 of 20
Re: Unable to get login screen
There would appear to be a problem at BT's end.
Message 3 of 20
Yes, getting much the same - will a slightly different 2nd line.
20260209T173108Z-1859ffbfd4b875q2hC1LONynpc0000000na000000000c9a1
Message 4 of 20
Is BT Email down?
Hi all,
I've just tried to log in to BT email this afternoon (9 Feb 2026) and all I get is a white screen with black text saying:-
"The request is blocked.", followed by a long line of code.
It's the same on both my computers, on one of which I use "Edge" browser, and on one of which I use "Chrome" browser. On the browser tab it says "Service unavailable". This is on webmail.
Is anyone else having the same problem, or aware of the problem?
Message 5 of 20
Re: Can't access my BT e-mails
If you look at Down Detector, they've had over 1000 reports re no emails access today
Message 6 of 20
getting same message , on my laptop , tablet , firefox  .microsoft edge, must be BT end
Message 7 of 20
I have the same  'The request is blocked' problem.  However, it is also blocked on my iPhone.
Message 8 of 20
Hi, yes, I've got the same and have just posted a similar query (not having seen your post).
Mike.
Message 9 of 20
Yep 😞
OK on my Android
Message 10 of 20
If you check Down Detector there's problems with bt emails today, theres been over 1000 reports this afternoon
https://downdetector.co.uk/status/bt-british-telecom/
