Message 1 of 5
eMail addresses
I have 3 BT email addresses which I use on Lap top and iPhones. On the iPhones only I also have an address called Btinternet which is accumulating old emails. Can I delete this without losing any function
4 REPLIES 4
Message 2 of 5
Re: eMail addresses
If it is an email address that you no longer use you can delete that without it affecting any of your other email addresses.
You will lose any of the emails that are in the email address that you are deleting so if you want keep any of the emails you should either do a back up or forward them to one of your other email address that you are keeping.
Message 3 of 5
BTinternet
I have 3 BT email addresses which I use on Lap top and iPhones. On the iPhones I also have an address called Btinternet What is the purpose of this. Thank you
Message 4 of 5
Re: eMail addresses
Thanks for getting back. No it is not an old address. It is just "Btinternet" that's all and only on my iPones. It seems to hold some, not all of old messages and is now up to over 5400. This all came up when I noticed my wife was having to delete the same emails from both IPone and IPad
Message 5 of 5
Re: eMail addresses
If you are still using the email address don't delete it. Just delete the emails you don't want.
