Message 1 of 6
email access
I have no access to my email. I have tried everything even restarted my router. It says its not down
5 REPLIES 5
Message 2 of 6
Re: email access
Morning @Ron90
Thanks for coming to the community.
Our Get help with My BT login and BT Email login page, has advice on accessing your email and troubleshooting to get this sorted.
If you could try the steps in the help page and let me know if you have any problems getting logged into the emails after doing this 🙂
Thanks.
Leanne.
Message 3 of 6
Re: email access
Thank you, in the end I had to ring them and the help received was first class. Thank you again, take care.
Message 4 of 6
Re: email access
Morning @Ron90
Thank you for coming back and letting me know 🙂
Glad this has been sorted for you and the service was excellent when you called.
Have a great Friday.
Leanne.
Message 5 of 6
Re: email access
If your email service isn’t down but you can’t access it, try clearing your browser cache, using a different device or network, or checking your account recovery options. If none of these work, contact your email provider’s support directly.
Message 6 of 6
Re: email access
Thank you, problem solved
