danielle1
Message 1 of 17
0800 800 150 "not recognised"
I've been trying to call the BT 150 number all day but the number is "not recognised".  In fact, the message kicks in after the second 800, so before I've even finished entering the number
16 REPLIES 16
imjolly
Message 2 of 17
Re: 0800 800 150 "not recognised"
From landline or mobile ?
bt Retail customer?
danielle1
Message 3 of 17
Sorry, I should have said.
Yes, BT landline, retail customer.
imjolly
Message 4 of 17
If landline you just need to dial 150
Keith_Beddoe
Message 5 of 17
Perhaps you have a crossed line?
Dial 17070 and see if the number that is read out, matches the phone number on your bill.
danielle1
Message 6 of 17
Well, I'm glad to find out that I can just dial 150 (thank you!), but now ... do I have a new problem?  I just tried the 17070 test, and I got a completely different number.  What does that mean, in laymen's terms?
imjolly
Message 7 of 17
You have a crossed line and need to report it - guess where - 151
Keith_Beddoe
Message 8 of 17
It means that your line is crossed with another, and the other person`s calls will appear on your bill, and vice versa, It will also cause problems with your broadband.
If you make a note of the number that is read back, and tell BT that your line is crosseg with that number, then they will get Openreach to look at it.
It could be a number belonging to another provider, but then you would not get BT if you dual 150.
It could also be a "stopped" BT line, which usually only allows calls to 150.
Was it a broadband issue to were trying to report?
danielle1
Message 9 of 17
Many thanks for the info.  If I hadn't had a problem with the new hub confusion, I would have never known about this crossed line.  All the bills are correct, as far as the calls listed.  I always check everything.
But might this be in any way connected to the second hub being ordered and delivered (see my only other post)?  Or is that just a coincidence?
danielle1
Message 10 of 17
No, I was trying to call about the second order for a Hub 2 appearing on my account and the Hub being delivered (see my other post).  I wanted to make sure the mistake was cleared up.
