Message 1 of 3
Add landline
I have broadband only account, does anyone know how or if I can have landline added?
2 REPLIES 2
Message 2 of 3
Re: Add landline
If you now want broadband and ability to make calls then you will need to start a new contract   you can try phoning options team and see if they can help you 0800800030
Message 3 of 3
Re: Add landline
You can add it when you want, as mentioned it would renew the minimum term, the extra cost depends on the calling plan you choose, your options are pay as you go (PAYG), 700 minutes or unlimited minutes.
