Message 1 of 6
Advanced digital voice phone with Alexa built-in
Could anyone please tell me if these Alexa phones are locked in to only work with BT Smart Hubs or if they’ll work with any router?
5 REPLIES 5
Message 2 of 6
Re: Advanced digital voice phone with Alexa built-in
They are specifically made for BT's Digital Voice service which requires the use of the BT Smart Hub 2
Message 3 of 6
@Chasloyal
The phones are DECT, and connect to the DECT base station in the Smart Hub 2, so would not work with any other router.
Message 4 of 6
Thank you for the rapid reply, we have got the Smart Hub 2 but have been pondering changing it to an Asus so is there absolutely no work around?
Message 5 of 6
No, you have to use the Smart Hub 2 as the main router, but you could connect the Asus to a LAN port on the SH2, and use it either  a wireless access point, or as an additional router on a different subnet. That can give issues with remote access from the Internet.
Message 6 of 6
Sorry about the very late reply, thank you for clearing that up for me. We’ll stick with the Smart Hub 2 then.
