allybally361
Message 1 of 3
BROADBAND SUSPICIOUS ACTIVITY CALLS FROM BT
I keepgetting calls alleging to be from BT Open Reach saying there is suspicious activity on the line and now they have phoned to say tyhey are cutting both the land line and in ternet off
How do ou contact BT?
2 REPLIES 2
Message 2 of 3
Re: BROADBAND SUSPICIOUS ACTIVITY CALLS FROM BT
Without doubt this is a scam - similar instances have been reported hundreds of times of this forum.
The Moderators have posted a useful summary on the subject.
BT don't make these kind of calls and another clue is their reference to BT Openreach .  BT and Openreach have been separate entities for some years.
If you have details of the number you were called from then BT would encourage you to report it here.
Devon_Dave
Distinguished Guru
Message 3 of 3
It's a scam, just ignore the calls
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
