Message 1 of 5
BT Advanced Digital Home Phone with Alexa built-in
Hi, new Fibre 1 subscriber with a BT Advanced Digital phone paired.  I need more phones, but before I do I wanted to check that my phone will be compatible with FTTP when we get it hopefully Q2 2023.
Can anyone advise please?
Jeff
4 REPLIES 4
Message 2 of 5
Re: BT Advanced Digital Home Phone with Alexa built-in
Yes, digital Voice is totally agnostic to how your broadband is delivered.
Message 3 of 5
Many thanks for the prompt and helpful reply.
So the phone simply pairs to the FTTP router when it arrives?
Message 4 of 5
You won't get a new router, you already have a Smart Hub2
Message 5 of 5
Many thanks.
