Message 1 of 17
BT Digital Handset Screen
Is it possible to have the Digital Handset Screen permanently lit up and not just when the handset is in use?
16 REPLIES 16
Message 2 of 17
Re: BT Digital Handset Screen
just looked through settings and there is nothing under display to keep on permanently
Message 3 of 17
You could go into the Display settings and enable Screen Saver. This will give you a Clock when the phone is not in use.
Message 4 of 17
How do I find Display Settings?
Have scrolled through Menus and nothing for Display Settings.
This is a BT Digital Voice phone
Message 5 of 17
@Andy1234 Which Digital Voice Phone do you have?
  • Essential Digital Home Phone (Page 23)
  • Advance Digital Home Phone (Page 23)
  • Advance Digital Home Phone with Alexa (Page 30)
There are 3 User Guides in the link below:
Digital Voice: How do I set up my service? | BT Help
Message 6 of 17
I'm curious why you want to keep the display on all the time, this will drain the battery. Also the screen lights up when the phone rings thus acting as a visual indicator of an incoming call
Message 7 of 17
@Les-Gibson The Screen Saver is in a "dark mode" and the phone still lights up when it rings. I have the Screen Saver on and the battery drain is negligible and get the benefit of having a clock.
Message 8 of 17
Many thanks, I have now found the display settings on my Essential Digital Home Phone. Unfortunately it doesn't allow changing of screen colour or text size
Message 9 of 17
Like to have the display on when phone is on the charger for telling time.
Message 10 of 17
I think the text size can be altered under Accessibility settings .
If the Screen Saver is enabled the phone displays the clock whilst on charge and will light up when it rings.
