Message 1 of 5
BT Everday Digital handset
I have a BT handset which worked perfectly until our internet went off for nearly 24 hrs 5 or 6 weeks ago.  Since then it has only got an engaged tone.   If I dial 1471 I get a dialing noise over the engaged tone then nothing.  It doesn't register incoming calls either. I've reset it - done everything suggested in the manual.  I can't make or receive calls on it.  Any suggestions?
4 REPLIES 4
Message 2 of 5
Re: BT Everday Digital handset
Are you on digital voice with phone connected to back of hub or are you still connecting to the white phone socket on the wall?
Message 3 of 5
It's plugged into the wall - a second similar phone that we have upstairs works perfectly and hasn't had any trouble. I've relinked it to the hub. I've reset it. I've tried it in different sockets. I can't think of anything else to try.
Message 4 of 5
Sorry but now confused
If you don't have digital voice and use the normal phone socket then I don't understand why you are linking your phone to the hub. You only connect a phone to hub by dect or socket on back if you have digital voice. If you have digital voice then the old phone socket does not work for calls
Message 5 of 5
It's digital voice and a bt digital phone, given to us by bt to go with the new hub earlier this year. that has 2 plugs that go into electrical sockets.  Works over wifi.  We have an "old fashioned" phone that is directly plugged into the hub and works perfectly too.  We have 2 digital phones.  The other one is fine.  This particular one constantly has the engaged tone and doesn't ring with an incoming call or dial out and nothing I do changes it.
