Message 1 of 2
BT Everyday phone handset not ringing
I have a BT Everyday landline phone with two handsets. One rings for incoming calls, the other does not. The one that does not shows a musical-note icon, the one that does ring does not. Can I set both handsets to ring on incoming calls?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: BT Everyday phone handset not ringing
Sounds like you've turned the ringer off. Try pressing & holding the # key.
