Message 21 of 22
Re: BT Smart Hub 2 usable on phone extension?
@licquorice
Thank you for this.
It must be very difficult for you and people like Openreach because many of us have systems which have been tweaked to suit our own needs.
What I think I will try to do is install a piece of flexible conduit with a draw string into the void and make the job simple for the future.
Thank you.
John
Message 22 of 22
@RKMC
Thanks for this.
Well if I can get a 4G autodialler for £100 I think I will go down this road. It will be so much simpler.
Thank you for taking the time to reply.
John
