M_Danks68
Message 1 of 8
BT caller display and BT Basic
Is BT Caller Display available with BT Basic?
l have telephoned BT several times to get Caller Displayed added, but the option appears to have been disabled!
7 REPLIES 7
imjolly
Message 2 of 8
Re: BT caller display and BT Basic
Have you tried
To display the caller's identity on your phone's call screen, dial *234#.
To check whether your phone is set to display the caller's identity, dial *#234#.
To hide the caller's identity on your phone's call screen, dial #234#.
M_Danks68
Message 3 of 8
Thanks for the reply, but it didn’t solve the issue. Useful code, but it doesn’t add caller display to BT Basic accounts.
JohnC2
Moderator
Moderator
Message 4 of 8
Hi @M_Danks68, welcome to the forum and sorry you can't get the Caller Display service added to your line. I've sent you a Private Message with details on how to contact the Mod team and we'll be happy to help you with this.
cheers
John
M_Danks68
Message 5 of 8
Thanks.
Issue has been solved by the BT BASIC team.
Issue  was due to a software 'bug' and error message of the form "Sum of the [xyz] = sum of the [abc]".  The bug and error message was manually cleared from the IT system and CALLER Display is now active.
LFE:  BT BASIC customers must speak to the BT BASIC team as the normal customer service team may not have system authorisation to add 'applications'  to a BT BASIC account.
Laird2
Message 6 of 8
Hi can you please help me I would like to know how to get caller display with basic calls and help would be be very much appreciated. Thank you in advance
Laird2
Message 7 of 8
Thank you I have now got caller display thank you for your help
PaddyB
Moderator
Moderator
Message 8 of 8
Hi @Laird2,
Thank you for posting back to let us know.
Thanks,
Paddy
