Message 1 of 6
BT digital voice compability with ADT monitored alarm
Has anyone who has ADT monitored alarm been transferred over to BT Diogital Voice - need to know if the Alarm will be compartible for monitoring via digital voice for monitoring and also any issues during switchover. Thank you
Tags (2)
5 REPLIES 5
Message 2 of 6
Re: BT digital voice compability with ADT monitored alarm
Here's a thought, why not ask ADT?
Message 3 of 6
You'll need to contact your alarm company ADT as they'll need to check if monitoring unit you have is compatible or upgrade it to one that is - here's some info they have on their website https://www.adt.co.uk/blog/telephone-digital-upgrade
Message 4 of 6
Really helpful as I was not able to find the info on ADT website. Thank you
Message 5 of 6
Contacted and they will revert - will post here if any new info received
Message 6 of 6
Contacted who and they will revert to what?
