Message 1 of 7
BT digital voice
Do any digital voice phones have a headphone socket; essential for my wife's work
6 REPLIES 6
Message 2 of 7
Re: BT digital voice
You're able to use your existing phones, if you have a specific make and model for your needs such as a headphone jack. Just plug into the green telephone port on back of smart hub 2 (maybe covered with a sticker).
Or if you can't place your existing phone base station next to the smart hub 2 an DV adaptor can be used to wirelessly connect back to the smart hub 2 via its built in DECT receiver
Message 3 of 7
No.
You asked the same question yesterday and the answer has not changed
Message 4 of 7
Thanks but not quite the same question.  Yesterday I asked about the Alexa handset which BT would send me "free" if I renew my contract.  I was hoping there might be another DV option handset which had a headphone socket
Message 5 of 7
Thank you for the helpful reply.  If I do what you suggest with my current handset would it work in tandem with the DV handset when I din't need the headset?
Message 6 of 7
Message 7 of 7
Thank you
