Lister19
Message 1 of 3
BT exchange coverage per postcode
Hi all,
I want to be able to map the postcodes that each exchange serves. I realise i can find this on sites such as sam knows for individual postcodes on their tracker, but I need the full data set if that is possible?
Any help is appreciated
2 REPLIES 2
Devon_Dave
Distinguished Guru
Message 2 of 3
Re: BT exchange coverage per postcode
That info would not be available from this forum which is BT Retail /Consumer.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
licquorice
Message 3 of 3
Nor would it be available anywhere else in the public domain.
