Message 11 of 18
Re: BT's Home Phone Standard product
Pddco: Nice idea! I'd long since forgotten that the Journels were available. I did have a couple that took me right back to Strowger days but I fear they have been disposed of by the powers that be!
Message 12 of 18
iniltous: I believe the pdfs you included above have pretty much answered my question diagramatically, ie its a (presumably new) Line Access Gateway that does the functions that I was quering. So thanks.
Message 13 of 18
Thanks for being intrigued. I wouldn't have found what Home Phone Standard was without your enquiry. That it's just a latest name for packaging the PDPL via SOTAP for Analogue product. Thanks to all the contributors here for that.
Message 14 of 18
It's not made up terminology. The product is called Home Phone Standard.
Message 15 of 18
Does this new link suggest BT may now be offering the replacement analogue Home Phone Standard service to existing wired Broadband customers, by separating their Broadband onto a new line (provided by EE) while switching the original line over to Home Phone Standard for analogue landline only service?
https://www.bt.com/help/landline/changes-to-your-home-phone-and-broadband
Message 16 of 18
That makes absolutely no sense whatsoever, DV doesn't require full fibre connectivity.
Message 17 of 18
That’s a pretty poorly written article in my opinion but presumably aimed at a very small subset of BT ADSL broadband customers that currently also have PSTN telephony , and in their area there  is no SoGEA option to provide VDSL/FTTC and Digital Voice to replace it  , and apparently the solution now is to convert the PSTN service to PDPL and install a separate new line to supply an EE broadband service ( which will also be  ADSL ) which is odd in that previously it was indicated that SoTAP (ADSL without PSTN telephony ) was capable of delivering BT DV , a solution that doesn’t need a second line installed, just a suitable BT router , the customer already taking BT broadband and that PDPL was exclusively for existing BT telephony only customers (so those with no broadband at all ) this article suggests that has been dropped in favour of this two separate ‘lines’ approach.
I suspect the number of BT broadband and phone customers on ADSL /ADSL2+  that have no SoGEA option , and will need this convoluted arrangement, a new line to supply a separate EE ADSL/ADSL2+broadband service in addition to the existing line converted to a BT PDPL phone line to keep a both a broadband service and a phone service will be pretty small , and leaves  unanswered why originally SOTAP with DV (given the tiny bandwidth DV needs) wasn’t introduced as first alluded to when the PSTN switch off gathered pace …., I suspect they couldn’t make SoTap and DV robust/reliable enough and with time running out for PSTN decided this was a the next best option, however inelegant.
Message 18 of 18
Ah, that makes more sense now. Hadn't considered that corner case. Does seem a convoluted solution though.
